Hi,
A lot in that subject, but it's really one question to start with.
Again, new pool (about a month old), filled with well water (well, that ship has sailed - knowing what I know now, I don't know that I'd do that again...)
Went from using test strips (Frog brand, came with my Pool Tender) to TF Pro - I'm still new to using it, so take my readings with that in mind... I may be doing it wrong
(I have read the instructions that came with it, plus the extended instructions I found here - they're much better, and should come with it!)
Current numbers (some a couple days old, some a couple hours old):
FC : 3ppm
pH: 7.2 (I think, and there's a reason it's low right now - I'm working to lower TA)
TA: 200ppm (down from probably over 275)
CH: 650...? I'm not confident in this number
CYA: 55 (I've deliberately got it a bit high, as I was flying through chlorine)
I was having a problem with my pH going up "continuously", and also noted that adding ph-down wasn't nearly as effective as the instructions indicated it should be.
I've since read all I can find here about TA and pH, and now understand that with my TA so high as it was (and still is), it would tend to ratchet my pH up fairly quickly. So, I'm on a mission to lower TA. I've build a PVC aeration aid device (as shown in a few posts elsewhere), and I've been doing the add acid (switched from using Dry Acid / ph-down to usinng Muriatic - 31.45% now) to get pH down, then aerate.
It's making progress.
I've added 4 gallons so far (over about 12 hours) and the pH hasn't gone down nearly as much as I expected (hence, I'd keep adding more - leaving at least 20-30 mins between a pour and a pH read, with the pump running).
My question: Is it normal for it to have a reduced impact (relative to what the calculators indicate you could expect) due to the high TA? Or is it normal that the calculations (even from Pool Math) are wildly wrong compared to reality?
I feel like I'm making progress, just curious why I was able to add four gallons in such a short time frame to get the pH down. Actually, I think to get from 8.4 to about 6.8-7.2 (hard to read), took be about 3 gallons over about four hours. Added another gallon this morning, as it was back up to about 7.2 (with more confidence).
(I probably just need a better way to read pH - I suck at this color comparo game!)
Thanks
FC : 3ppm
Thanks
