- Jun 22, 2014
- 52,071
- Fiberglass
- CircuPool RJ-45 Plus
Re: New Pool - Cloudy Water
Look around for the sand. IT should be #20 silica pool sand. Stay away from the Quickrete brand at HD. Other than that, just pool sand should be fine. I would measure the suction opening to be safe so you get the right plug(s). Some people installed shut-off valves to help isolate the pad for times like this. Might be something to consider. Other than a plug, you might get by with something else (i.e. tennis ball), but if not, measure to be safe. Some Zeosand may seep out, but not a ton. You'll want to have a tarp or something nearby to scoop it to as you empty the filter. A Shopvac may help towards the bottom. Some Teflon tape on the threads may not be a bad idea. Take your time on refill to not damage anything once full. It stinks to have to go in there twice.
