- Jul 26, 2019
- 6
- Plaster
- CircuPool RJ-60 Plus
Hello,
First Pool and fourth day of operation of pool. Concerned about my water test results and am unsure if I should run screaming to pick up 20 mule team, let the bubbler work to raise pH and lower TA or adjust CH, or all or nothing to do.
The following tests were done using Pentair Rainbow test kits that the builder supplied.
Startup test in afternoon: FC 0.0, pH 8.2, TA 370 Pool startup guy added 11 gallons of muriatic acid, unkown strength and several cap fulls of 73% Cal-Hypo
Day 2 test in evening: FC 0.5, pH 6.8, TA 120, CH 250, CYA 30 I added 8.9 oz by weight of 73% Cal-hypo
Day 3 test in evening: FC 1.5, pH 6.8, TA 150, CH 250, CYA 30
Now using Taylor Test Kit can also repeat numbers using Pentair kit if needed.
Day 4 test this morning: FC 4.2, cc 0.0, pH 7.0, TA 130, CH 150, CYA 40
Will of course run both sets of tests if needed for comparison, or whatever is needed for data.
Thank you very much for your time and consideration,
