The acid needs to be were you can get to it easy as the first few months on a new pool your PH will push up due to the plaster curing.
Chlorine-you will need for the first 30 days. Your SWG will not be turned on during this time so you will be adding chlorine every day. Once your SWG is turned on you will want to keep liquid chlorine on hand to push up the FC if you have a big group of people over or something gets into the water (people waste or critter).
Other than these two you will not need many chemical on a daily bases.
Kim
Kim
