- Jun 22, 2014
- 47,961
- Fiberglass
- CircuPool RJ-45 Plus
Ahhhh, the constant *click* *click* *click* sounds of the chisels for the stonework... It looks like they're making good progress! We had drama with out autofill/sprinkler connection as well. The landscape installer ended up bypassing and going straight to the main, since they couldn't find all of the leaky valves. I also had to replace the stock float in our autofill, as it didn't seal well with our high water pressure. Which type of autofill are they installing?Tile and stone work started yesterday. Wife is happy with here selections and that's really all that matters!
On another note, I had 2 irrigation shovels "disappear" that the builder is now replacing. I know I should have put them up but I was out working late Sunday night and just didn't think about it.
They piped for an autofill that is supposed to be tied into our sprinkler system, unfortunately I haven't been able to read the persons mind that installed our sprinkler system and they are no longer in business (not shocking because its a disaster). With that said, I decided to tie into the main water line back at the equipment pad and run a new separate sprinkler system specifically for the auto fill and the landscaping on the back side of the pool. Hopefully that will all be completed today or tomorrow.
Yeah, I think it looks good and with the steps on the spa side leading to pavilion it will be a nice addition. Cost? Oh yeah, I was told it was going to be around $4k-$5k for the walls on both sides.....AFTER they had already finished one side. That's not how that works, so we came to a VERY reasonable compromise. Truth is we were going to need a wall of sorts on both side to help with drainage due to the slope in our yard, the problem boiled down to simply how it was all handled.It probably would have looked slightly better if they used plain concrete blocks and did the stone to match the wall, but honestly it doesn't look bad. They also likely would have had to order more stone, and who knows whether it would have been a perfect match. It's certainly worth a conversation, but I wouldn't be too mad, unless they try and hit you with additional cost.
I've seen your retaining wall before while browsing the site and always thought it looked good.I think it (the wall) looks OK. As you can see from my avatar, we have a pretty significant retaining wall. I am not a huge fan of the color, but it's not too distracting.
Oh, and I assume you are an OU fan. In that case...GO POKES!!!!
I agree! Finished deck is better than we hoped.Pavers looking good!
--Jeff
