Requirement is 4' height minimumWhat does your code say? Find this out they we can move forward.
All private swimming pools now existing or hereafter constructed, installed, established or maintained, with the exception of wading and portable pools, shall be completely and continuously surrounded by a permanent durable wall, fence or barrier which shall be no more than six feet nor less than four feet in height above grade and shall be so constructed as to have no opening, mesh, hole or gap larger than two inches in any dimension, except for doors and gates; provided, however, if a picket fence is erected or maintained, the horizontal dimension of any gap or opening shall not exceed 2 1/2 inches. No fence of any kind or material shall be constructed or maintained which shall contain projections of any kind at any point on the outer surface of said fence. A dwelling house or accessory building may not be used as part of such enclosure. All gates used in conjunction with any of the above-described enclosures shall conform to the specifications required above as to height and dimensions of openings, mesh, holes or gaps in the cases of fences, and all gates and doors shall be equipped with self-closing and self-latching devices for keeping the gate or door securely closed at all times when not in actual use. Latches shall be a minimum of four feet off ground level. Gates and doors shall be locked when the pool is not in use or is unguarded or unattended; provided, however, that nothing herein contained shall be construed to require the construction of an additional wall, fence or barrier where, in lieu thereof, the entire premises or a part thereof wherein the pool is contained shall be fully enclosed by a wall, fence or barrier which meets the specifications set forth herein. No fence shall be closer than six feet from any point of the pool.
Oh it will definitely be a pool compliant fence. I've made it clear to the fencing contractors and will run it by township before I sign off anything.
My questions were just in regard to the general design and layout of the fence relative to the pool and how much space to give between patio and fence if I wanted some plants in there. And assuming the height is at the min height to code whether there is any benefit to go higher.
+1.I've made it clear to the fencing contractors and will run it by township before I sign off anything.
Yes. That sounds like a good idea. I'll look into that from HDYou risk the walls and bottom of the pool getting ruined by a heavy rain and the run off from it. The walls could collapse and the vermiculite may get channels from the run off.
One thing you can do is put up a temporary fence with push in metal poles and metal fencing such as this:
Everbilt 4 ft. x 100 ft. Galvanized Zinc-Coated Welded Wire 308312B - The Home Depot
The YARDGARD 4 ft. x 100 ft. Welded Wire is made of galvanized zinc-coated steel for long-lasting use and features 2 in. x 4 in. mesh for strength and 14-Gauge wire for durability. The general purposewww.homedepot.com
Best go ahead and put in the liner and fill it up to save your a lot of heartache and money.
2. What do I do about rain water when it pools on bottom of vermiculite?
I'd recommend getting a submersible utility pump.
I used this guy during my build to pump out numerous rain storms. Now I use it to pump the water out during winter.
1/3 HP Submersible Utility Pump 2000 GPH
Amazing deals on this 1/3Hp Submersible Utility Pump 2000 Gph at Harbor Freight. Quality tools & low prices.www.harborfreight.com
If you are only looking at the outlets for landscaping lighting, another option is run electrical conduit from the equipment pad to around the edge of your pool or deck and run the low voltage cable(s) inside it. Then you could control them with your automation panel. If you are looking at just low voltage landscaping wires in the conduit you could use 3/4". If you want to also use it for speaker wire I would upgrade to 1" conduit. For my pool I bought the conduit and asked the electricians how much they warned to install it. It only cost a couple hundred dollars. They bent it with heat instead of having to buy (and sometime fight the angle of the fittings.) I also ran a separate 3/4" conduit run foe my 120VAC outlets. I ran extra extra conduits in every location I could think of.Good morning,
I am looking to add 3 additional receptables around my pool. I received a quote with the following to each of the corners ($1900). They will be wiring into an existing GFI breaker (that already controls 2 existing pool intellibrite lights + outlet (see picture) by the the equipment pad. The total supply to pool panel is 50 amp. The goal of adding the outlets is to add landscape lighting features as well as convenience, also I do want to add lamp posts down the road. Not sure if adding 3 is overkill, but it would be placed outside deck at the 3 corners of the pool.. I just want to do it now while pool is still in building phase and not have to worry about it later.
1. Does this make sense or should a new GFI breaker added?
2. What do you typically use outlets for?
View attachment 479609View attachment 479610
Bonus picture of backfilled pool and I put X where new outlets would go:
Good idea. Thank you!If you are only looking at the outlets for landscaping lighting, another option is run electrical conduit from the equipment pad to around the edge of your pool or deck and run the low voltage cable(s) inside it. Then you could control them with your automation panel. If you are looking at just low voltage landscaping wires in the conduit you could use 3/4". If you want to also use it for speaker wire I would upgrade to 1" conduit. For my pool I bought the conduit and asked the electricians how much they warned to install it. It only cost a couple hundred dollars. They bent it with heat instead of having to buy (and sometime fight the angle of the fittings.) I also ran a separate 3/4" conduit run foe my 120VAC outlets. I ran extra extra conduits in every location I could think of.
Okay. That is reassuring to hear. I have 6" radius corners. Definitely everything gets overanalyzed and questioned with the amount of money, time and stress going into this project. Almost at finish line though. Patio guys started today!I've got an identical set up that was installed Oct of 2022. Full length 16' vinyl covered steps on the L. My corners look very similar. I don't have any close ups of them, but can send some if you'd like. I have 6" radius corners, and looks the same for you? They are never going to be perfect on the top step, there just isn't enough water pressure. You're probably really noticing it for two reasons: one, we overanalyze everything on our builds () and two, the tile pattern probably makes it stand out more than I notice on mine (Bali/Blue Granite by Latham) I am 100% satisfied that I went with the vinyl covered step instead of the fiberglass insert though even with the imperfection, FWIW. If you fill the pool all the way over the skimmer, that might help push them in and then lower it back down to where it needs to be. That's sort of what happened with mine over the winter as the pool filled up through snow/rain through the safety cover.
