We have received a bid from a pool builder we will most likely go with. I would appreciate it if some of you pool veterans could look at this and tell me if there are any glaring omissions or things we haven't thought of but should. The one thing that caught my eye at first glance was there was only one pool light. Is it worth it or necessary to add a second? Eager to hear your feedback on all!
Pool Shape: Custom
Pool Perimeter: 109 LF
Pool Area:615 Sq. Ft.
Max Length 34 Feet
Max Width 18.8 Feet
Pool Minimum Depth 3 Feet
Pool Maximum Depth 6 Feet
Approximate Gallons 20,756 Gallons
Spa 40 sq. ft. Raised 18 inches
Structural Specifications:
Excavation: BOBCAT dig/ Home owner to determine access.
Steel Schedule: 4 x 1/2" Box Beam, pool cage to be 3/8"x 10" O.C.B.W.
Pool Structure: Beam to be a 12" box
Pool walls minimum 6"
Pool floors minimum 6"
Coves minimum 8"
Deck dowels to connect pool to decking
Equipment Specifications:
Pool Filter 430 Cartridge with Spa
Filter Pump 2.7 HP VS Pump
Feature Pump 2 HP
Pool Cleaner In Floor
Sanitizer(s) Rainbow 320 Chlorinator and Ozone Joe Ozonator
Heater Hayward 400.000 BTU Heater
Pool Lights 1 Hayward LED Pool Light(s)
Air Blower 1.5 HP Polaris QT Blower
Warranties
Equipment 3 Year Warranty on Equipment
Gunite Warranty Lifetime Structural Warranty
Craftsmanship Warranty 1 Year Warranty on all pool workmanship
Mechanical Specifications:
Skimmers 2 Hayward
Pool Returns 4 1.5" Schedule 40 PVC
Pool Main Drains 2 Anti Entrapment, VGB Compliant
Spa Main Drains 2 Anti Entrapment, VGB Compliant
Pool, Lights and Equipment to be wired persuant to current NEC code.
Sub Panel Included No
Pool Coping, Decking and Drainage:
Coping Material Natural Stone Travertine, Slate, Quartzite, Leuders
Waterline Tile Standard Ceramic
Deck Size/ Material 1330 Sq.Ft. of Stamped Concrete (400 sq.ft.min)
4" Drainage 75 LF
Deck-O-Drain 0 LF
Overflow Line Yes
Fill Line Auto with Vacuum Breaker
Pool Interior
Swimming Pool Interior: Wet Edge Pearl or Satin
Prism for Spa only
Pool Controller
Automation: PDA Prologic PS-8 - Pool Spa
Additional Items
Raised Beams 16 ft of 12 inch raised beam and 15 ft of 18 inch raised beam with ledge stone facing
Pool Entry: Tanning Ledge Per plan with dual bubblers
Benches: Per Plan
ETA: I just realized that our bp has a chlorinator listed when we want a SWG. Will update again once that is changed.
Pool Shape: Custom
Max Length 34 Feet
Max Width 18.8 Feet
Coves minimum 8"
Feature Pump 2 HP
Warranties
Skimmers 2 Hayward
4" Drainage 75 LF
Deck-O-Drain 0 LF
Overflow Line Yes
Pool Interior
Prism for Spa only
Pool Controller
Additional Items
Benches: Per Plan
