- Aug 4, 2016
- 4
- Plaster
- Pentair Intellichlor IC-20
So after moving and having a pool built I've been chasing the chlorine levels. Discovered after pool builders one month service to maintain water while pebble cured and then added salt and plugged in the SWG, I found there was no stabilizer. So chlorine was disipating and the SWG couldn't keep up. So now I have added stabilizer at 50ppm. So after reading many posts I'm going to do an overnight chlorine test. These are my numbers as of a few minutes ago.
FC 7.5
CC 0
PH 7.4
TA 70
CH 280
CYA 50
So if my chlorine rises over night then drops during the day tomorrow back to these numbers I guessing everything is working as it should be. Right now SWG is running at 60%. Thanks for letting me rant and let me know if I need to look at anything else.
FC 7.5
CC 0
PH 7.4
TA 70
CH 280
CYA 50
