We just got new plaster 2 weeks ago, and have been testing, balancing, brushing, and vacuuming religiously. The water looks great and is crystal clear and have been pleasantly surprised that we have not had much pH rise over the last 2 weeks. I guess I expected to be adding acid daily, which we were used to when the SWCG was running (no salt added yet), but it has been maintaining in the 7.2-7.5 area with very little intervention from us. Is that to be expected? Could it be due to the rain we've been getting, I've heard that may lower pH, so maybe I'm getting an assist from nature? I'm actually questioning whether we ever go back to the SWCG, because managing the pH rise was a daily effort, and I suppose not any more difficult than manually dosing chlorine daily. May just switch back to bleach permanently if this helps keep pH in check.
While everything else seems to be in line, we've had Combined Chlorine levels in the 1-1.5 area since start-up. There are no signs of algae, and the FC levels are in line with current CYA levels. I don't want to raise them to SLAM or SHOCK levels since the plaster is brand new. So is the CC level of any concern and do I need to do anything about it at this point?
Finally, unrelated to the new plaster issue, I can no longer find plain old bleach in any stores (everything is either splashless or scented, and even "Regular Clorox" looks to have some sort of fabric protector added). Any brands/stores that I should be looking, or am I doomed to have to buy liquid chlorine at a pool store?
Thanks in advance!
Thanks in advance!
