- Jul 21, 2013
- 66,063
- Plaster
- Pentair Intellichlor IC-60
The calcium in cal-hypo accumulates just like CYA and high calcium will cause scaling on pool surfaces.
We have NST prime extended release non stabilized calcium hypochlorite tablets.
Yikes. Sounds like it’s best to avoid the tablets all around. I’ll use them as minimal as possible.
Is it common for ph to rise often in a new plaster pool?
Should I add any liquid chlorine?
Ph 8.2
Ch 2
CYA 40
Alkalinity 100
Also the alkalinity test turns dark pink and not red is that common?
Okay good. And is it common to need to add small amounts of acid almost daily with a new pool to keep ph I’m the 7 range? I’m using the chemical calculator from this website to get my acid calculations based on ph level.The color change from green or blue to red/pink/whatever is what matters.
My Ph seems to like hanging out at 7.8 to 8.2. I add the acid and it comes down to eother 7.2 or 7.5.What is the pH level when you add acid and what do you lower the pH to?
TA of 100 contributes to the pH rise. As your TA drops the rise will slow down a bit.
Let your pH hang out where it likes. Don’t reduce it until it is 8.2 and then only down to 7.6.My Ph seems to like hanging out at 7.8 to 8.2. I add the acid and it comes down to eother 7.2 or 7.5.
There’s absolutely nothing wrong with it hanging out at 7.8 or 7.9. When hits 8.0+ it’s time to adjust but no need to go way down to 7.2. Maybe just 7.6 because it rises quickly through the low sevens and will rise slower in the upper sevens.My Ph seems to like hanging out at 7.8 to 8.2. I add the acid and it comes down to eother 7.2 or 7.5.
YesOkay good. And is it common to need to add small amounts of acid almost daily with a new pool to keep ph I’m the 7 range? I’m using the chemical calculator from this website to get my acid calculations based on ph level.
