New Plaster Issue
MAS
0
10
Bernardsville/NJ
Good morning. We had our pool replastered with Super Blue Diamond Brite in early May of last year. We did everything we were instructed to do by the replastering company and religiously kept the water in balance all summer (we went through gallons and gallons of muriatic acid to keep the Ph under control). We then closed the pool for the winter as we normally do. We opened the pool last week as we normally do and it cleared up within a day or two. The water is now in balance according to the pool store test on Saturday morning. (FC = 2, TC =2, pH = 7.2, Hardness = 158, Alkalinity = 80, Cyanuric Acid = 37, Copper = 0, Iron = 0). I now know from reading TFP that these pool store tests aren't always accurate, but I don't have the TF-100 kit (yet), so these readings are the best I have right now.
The water is perfectly clear and everything looks good except the plaster. There are very rough (like sandpaper) and somewhat discolored spots all over the pool surface where the water level was dropped to for winterization. From reading various posts on TFP, I suspect this is calcium scaling due to the pH levels being out of control while the pool was closed. I don't know how we could have controlled this during the winter, but it is what it is and now we have to fix it. So what's the best way? I have read some posts that say to keep the water balanced and it will disappear over time, some say an acid wash is required, and some say an acid wash without draining the pool will do the trick (I don't think I can go that route because I cannot isolate the heater). Any suggestions are appreciated.
Welcome to the club. You can read about my saga here - Replastering a Pool - A 1 Year Saga - Problems Lessons Learned
I had problems with a replaster job and so did two of my friends in the area.
The plaster guys who came back to fix the problems did not seem suprised and knew exactly what to do. I think this may happen more then we know. Depends how picky the customers are. Plastering pools seems to be a very in exact science.
I think you are on the right track. Depends how bad things are if an acid wash alone will satisfy you.
I would think they can turn off your pump and put winterizing plugs in your skimmer and returns during the acid wash. They can use portable pumps to stir the water until they get PH back to normal.
So what was the remedy as you state "The plaster guys who came back to fix the problems did not seem suprised and knew exactly what to do."
Excellent info and thanks for sharing!
Wow. You’re pool was definitely much worse than mine is. Sorry it was such a PITA for you but I’m glad it’s better now and the builder stood behind their work and fixed it. I just talked to a local pool guy and he said to add 3 qts of something called Orenda SC 1000. The guy is crazy nice and knowledgeable so I plan to follow his advice. Just wondering if anyone here has heard of it and/or used it.
