New plaster/high PH. Vacation???
Jrclark403
3
19088
I’m at 6 weeks post replastering and fighting high PH which is expected. The ph is rising about .5 per day. We’re going on vacation next week for 5 days
My tentative plan is to:
Lower Ph to 7 before leaving
Shut off SWG
Put 3 pucks in a chorine floater
Any other thoughts/ideas?
FC 5
TA 90
CA 375
CYA 60
I would not turn off the SWCG. Lower the generation a bit if you like, but not turn it off.
How many gallons is your pool? With only using 3 pucks, best be under 10000 gallons.
Lower pH to 7.4, keep your SWG running, and enjoy your vacation.
No need for pucks with a SWG.
The way you are doing it with a pH of 7 and pucks adding more acid you will take your pH below 7.
