- Aug 8, 2024
- 274
- Plaster
- Pentair Intellichlor IC-60
Got the new plumbing setup all dialed in today. Added heater bypass, pentair multi port valve, high temp unions, check valve, SWCG power box, removed all 90* fittings and replaced with long sweep 90s and 45s. Moved booster pump over and off-line chlorinator back to create more floor space.
Dropped about 75 rpm..150 watts to 118 watts.
Still need to plumb in/wire SWCG, plumb chlorinator back in, install pump suction side high temp union and install 90* fittings on the pressure side of the booster pump.
Would you guys bypass the heater bypass when running the heater or allow some water to flow through the heater and leave the bypass open to allow water to flow both back to the pool return and through the heater?
