Greetings everyone! I am a new owner with a 17,000 gal inground fiberglass pool with a SWG. The pool was just completed a week or two ago, and since I have been cleaning and balancing water, and have it in great shape thanks to TFP! I do have a few questions about the pump, however. I've found answers to everything I need here on the forum except how to calculate and program pump cycles. It appears that my max flow is about 42 GPM at full RPM of the motor. If I am at 1/2 RPM, is the GPM flow about 1/2 of that? If I program to turn the pool over once at full RPMs, that would take about 8 hours of run time. Would 16 hours at 50% RPMs be the same thing? Would it filter as well, produce the same chlorine, and skim as well at lower RPM? I am thinking that it would filter just fine, but might not skim as effectively. I'm just looking for some general guidance here on how to come up with a pump cycle and timer plan.
Regarding freezing....I live in middle Tennessee. We often have temperatures that dip below freezing. Occasionally we get better cold, although the coldest forecast on the horizon is about 20 degrees. I activated the "low temp operation" in the configuration menu. As I understand it, that will turn the pump on high for 8 hours if the ambient temp is below 39. I assume that would override the regular cycle? At the end of 8 hours, if the ambient temp were, say, 20 degrees, would the pump start up again and run for 8 more hours? The manual says this mode is not for freeze protection, but I assume that in fact it really is for freeze protection. Any suggestions on this freeze protection or other cold-weather programming safety measures?
I look forward to hearing what the experts say - thanks everyone!
