summertimesadness
- Aug 23, 2022
- 393
- Vinyl
- CircuPool RJ-60 Plus
If it's equivalent (or, as you mentioned, easier) to do the app, I'll stick with that. ThanksSWG Run Time Calculator
What is the SWG Run Time Calculator? A tool that is designed to answer the common question of "how long should I run my pump/SWG". It calculates the run time of your SWG and Pump based on your pool size, the output of your SWG and your daily FC PPM loss. It is designed as a starting point...www.troublefreepool.com
Might be easier to use "Effects of Adding" in Poolmath.
