New owner overwhelmed
Jimrahbe
15,355
Bedford, TX
TRP,
You want your FC to correspond to the amount of CYA you have per this chart... FC/CYA Chart
If your CYA is 30 you what your FC to be between 4 and 6, but still OK all the way up to 12 ppm.
I almost always error on the high side...
Trp3383
19
08210
I was at 5ppm last night with chlorine, I did a vanishing act this morning and now fc is at .5ppm and cc is at .5ppm so I'm at 1 ppm TC. Should i bring back up to 5ppm?
Jimrahbe
15,355
Bedford, TX
TRP,
How is that possible if you have a SWCG? How long do you run the SWCG and when?
The answer to your question is YES.. You must always keep your FC well above the minimum.. Get some Liquid Chlorine.Bleach in there now.
Forget about TC... you want to keep your FC at the right level..
Trp3383
19
08210
It's the caldera fresh water salt system. THey told me to use dichlor or liquid chlorine in the beginning because the salt system takes time to start generating.
TRP,
Jimrahbe
15,355
Bedford, TX
TRP,
I have no clue what they mean by "won't work right away" :scratch: Your salt system will either make chlorine or it will not... What turns it on or off? What tells the system how much chlorine to make? Does the manual say how the system works?
Edit... What specific Caldera spa do you have? What is the model called?
Trp3383
19
08210
TRP,
It's a caldera reunion.
Backcountryski
46
WA
TRP,
My manual says the same, that it may take up to 24 hours. I suspect what they mean is it may take that long to produce enough to be at a good level. That along with no CYA in the water yet....I used dichlor for a few days.
