- Jun 22, 2014
- 47,854
- Fiberglass
- CircuPool RJ-45 Plus
This has been quite a journey huh? The slow draining has been exhausting I'm sure. But you're not quite out of the woods yet. The extended time it took to drain and refill has allowed algae to start. Even at that, your CYA is still pushing 90 which, while much better than what you had before, is still higher than what we normally recommend. So lets recap your options from here:
1 - Do another partial drain (50% or so) to get your CYA down to about 40-50 making a SLAM and pool management easier down the road
2 - Prepare to adjust chemicals at your current CYA of 90 and prepare to SLAM at that level. If you decide this option, you will first need to adjust pH to 7.2, then increase FC to 35 and maintain that FC level of 3 until the water clears and you pass all 3 SLAM criteria (SLAM link below).
Either choice will work, it's just a matter of using a bit more bleach. Even if you didn't replace 50% of the water, and only had time for about 20-30% replacement, getting the CYA down to about 50-70% helps. I'm sure you're anxious to get things going this year, so I just want you to understand all your choices. We'll help guide you whatever you chose.
