Hello,
I have a few random questions regarding my spa after searching. I have a Spillway SW-505 Stratford raised spa w/ spillover that I need to clean. The spillover gets most debris out and I use the spa only mode to get some of the dirt through the filter but there's still sand/debris at the bottom that doesn't get picked up. typically leave the cover always on to avoid more debris build up. I can't use my robot so how should I clean it? I believe I have a bad check-valve so the spa nearly empties when the filter stops running so I could not repair it and have easier access to cleaning the spa but that doesn't seem like the correct approach. Also, the air control knobs are leaking air and one is nearly shut tight. How do I go about diagnosing this?
