- Jun 14, 2021
- 8
- Plaster
- Pentair Intellichlor IC-40
Hello All,
(This is going to be long, so bear with me)
I have been interested in the owner-build route ever since I came across the idea years ago. I am using an online company called DIY Pools & Spas. The program I purchased from them includes design, plot plan, construction plan, structural engineering, consultation throughout , and “wholesale pricing” on Hayward equipment. Fast forward to now, and I have received city permits, and pool excavation took place on Tuesday 6/29/21.
here’s a bit about my pool...
Pool - 12’x30’
84’ perimeter
approx 360 sq ft
9,800 gallons
3.5’ - 6.0’ depth
12’ x 6’ Baja shelf
12” raised beam along 30’ east side of pool
18” raised beam for middle 8’ section
2-24” raised block Columns between 12” raised beams and 18” raised beams
2-12” sheer waterfalls coming out of 24”raised columns
1-36” sheer waterfall in middle 18” raised area
- 1 fire bowl on each 24” raised column
spa....
7’ x 7’
28’ perimeter
6 jets
30” spillway into pool
12” raised entire spa
other specs.....
- approx. 250 sq fr concrete decking
- pebbletec finish
- cantilevered pool coping
Equipment.....
Pump- Hayward variable speed TriStar VS 950
Filter- Hayward SwimClear 4030
Heater- Hayward natural gas 400k btu
Fountain pump- Hayward MaxFlo VS 500
Purification- Hayward 950 AquaRite Salt System
My biggest struggle so far has been getting ahold of contractors. I work in the utility industry, so I have had no problem gathering multiple contacts for each trade over the past year. However with the demand so high right now across the country, these contractors are trying to balance there work, bidding, scheduling all in a very busy day. I know in the past, bids weren’t so hard to get, more so rule of thumb was that most contractors don’t like setting a schedule until they know the prior trade has complete there portion of the work. Now days, these contractors don’t even give time for a bid until they know there work is ready to be done which really sets a delay in between each work taking place. I’m sure I left a lot out, so please let me know if I need to clarify anything. I greatly appreciate you all!!
Thanks again!!!!
Thomas
Pool - 12’x30’
84’ perimeter
approx 360 sq ft
9,800 gallons
3.5’ - 6.0’ depth
12’ x 6’ Baja shelf
spa....
7’ x 7’
28’ perimeter
6 jets
other specs.....
- pebbletec finish
Equipment.....
Thanks again!!!!
Thomas
DIY Pools and Spas - 3424 N. Redda Rd - Plans 5-24-21.pdf2.4 MB · Views: 25
