I am in Louisiana and new to forum have been reading and ready to get some help. Started out 2 weeks ago with a green swamp, as my pump was not running all winter.
Got a lot of debris out of bottom and more or less started the slamming process. Not really sure I have been consistent enough but none the less, trying.
My water is now cloudy blue and I can see down about 1-1/2 feet. here are my stats from tonight:
FC 7.5
CC 25
ph 7.0
Alk 80
CYA 35
I think most of debris is now off bottom, considering using drop out to clear water and then start slamming process over. HELP! What should I do?
using tk2006 test kit.
15x30 above ground vinyl, sand filter, 1.5 hp pump, first time to try chlorine used bacquacil for about 5 years, last year used FROG system and after reading forum want to try BBB system
FC 7.5
CC 25
ph 7.0
Alk 80
CYA 35
