Hi I am new to this forum. I bought a house with a 24000 gallon inground pool with a deep end. First time pool owner and I cant illustrate enough how helpful TFP has been for me. Thanks all you guys for sharing all these info. However I am in a bit of bother here right now and need some advice. About three weeks ago my pool pump motor broke and after a lot of you tubing i decided to change it myself. Which I did successfully and my pump is up and running again. However it took me about couple weeks to get everything done. In the meantime the water got all cloudy. Anyway I learnt about the slam process here and did everything accordingly. The water is crystal clear now. I passed the oclt and my tc was at 0.4. So i stopped the slam process. Checked the fc around 3 pm and it came down to 1 from 10 since 6am . So i poured couple more gallons of 12.5% bleach in the evening and in the morning it was holding at shock level at 11. Checked it again now at 3 pm and the fc reafing is again 1. By the way my cya is 0. Should I add cya now or the pool is supposed to hold fc longer? Thank you.
