New member from Fort Myers, Florida with questions..
Longhia
1
Fort Myers
Just had my pool resurfaced and having issue w/2 things. First how should pool valves be positioned so I can get the pool vacuum to work. Second my pool heater display says “no flow” what do I do to fix as I do want the heater on
L,
Welcome to TFP... We can help, but have to understand your pool equipment better.
Post a couple of pics of your equipment pad showing all the valves and we can tell you what is what.
It would also help if you added your pool's signature. See mine for a reference.
Go to Setting and then Signature..
FLORIDA in the house!! Welcome to TFP!
Take and share a pic of the valves and we can get you going again! We need to know what kind of valves you have and how they are set up now.
Know that with new plaster we suggest not using any cleaners with wheels on them as they can cause tracks on the fresh plaster. Wait 30 or so days. You can use a manual vacuum that has brushes on the bottom instead of wheels.
Kim:kim:
