- Sep 9, 2007
- 63
- Vinyl
- Pentair iChlor 30
I have been experiencing a lot of water loss so I had my pool guy come out and check for leaks. He used epoxy to patch a couple at a light fixture and on the side, but said that one at the main drain and another at a Caretaker return could only be fixed by replacing the liner.
So I decided to do a bucket test with the pump off and after seven days the bucket water was 1 and 1/8" lower and the pool measurement was 2 and 1/2" lower. This proportion of evaporation versus leak was consistent each day of the test. 1/8" loss in the bucket most days and the about twice that amount of loss outside the bucket.
I went into my records and found that I put the current vinyl liner in during 2008, so it is about 9 years old. Should I just go ahead and get a new liner? Does that make sense that leaks could only be fixed by replacing the liner?
Thanks!
Thanks!
