So same problem as last year only have a new liner this year. Cannot pass my OCLT for over a week now.
Upon installation, installer said the main drain screw holes were stripped. Said that would put us back couple more weeks for him to return plus add around $1500. He said we didn’t necessarily need to have a main drain, so he covered it with vermiculite(?) and installed the liner. Started filling pool then turned off water where he instructed me to so he could come finish up. So it sat 2/3 full with no chemicals for at least 4 days until he returned (over father’s day weekend). Finished filling then took readings and adjusted using PoolMath. SLAMMING, brushing daily, pump running 24/7. I do see small amounts of dead algae (I assume) here and there first thing in morning
First reading this morning before any additions:
FC 14.5. (was 18.0 at 9:00 last night)
CC 0
pH 7.4
TA 125
CYA 40
Could it be my pump isn’t cycling the water enough ? I noticed my psi is a little lower than previously (when had main drain)
CC 0
pH 7.4
TA 125
CYA 40
