Hello. First time liner install here and I've run into a couple issues.
27 foot pool with 52 inch walls. Ground is not completely level, but not too far off either.
Main problem I've got a big gave between the liner and cove. After unibead liner is in, wrinkles are attempted to be pushed to the outsides and a shop vac was attached to pull it tight and prepare for water. I have about 1/8 of the pool where the liner is far from the cove. I don't think even with water, it'll stretch to the sand cove. The rest of the pool, I believe will settle with water just fine.
Is there an easy solution to this? I'm on my last ounce of patience with it.
