Started liner replacement today. We found 3-4 inch moderate band of rust around the bottom of about 70% of the pool.
I also found areas where the bottom of the wall is not in the plastic base but I don't think it's because the wall is rusted away though. I wire brushed the rust to remove loose rust and was going to hit it with primer.
Plan was to put pad over sand, then foam cove and liner. The pad instructions say pad then cove but youtube video I saw was cove then pad and can't find much info regarding that.
Not sure about pad or cove first, how to handle rust, and if it's ok to leave bottom of wall out of track in areas.
Any help appreciated. Thank you.
