Hello. I just had a pool built and it has the following devices with an iAqualink RS4:
Main Filter Pump
Second Pump for slide and waterfall feature
Airblower
Lights
JVA to control the floor vs jet water flow for the spa when the airblower is enabled powered by the Cleaner input
All is working. Then I added another JVA to the pump that parses water to the waterfall and the slide. It's powered via the Solar input and I can use the on/off switch to turn the valve manually.
How do I get a function in the iAqualink app to allow me to turn that JVA to waterfall only, slide only, and both on together?
Do I need to turn the Dip switches? How do I configure in the aqualink.
I cannot find any usable documentation.
Thank you
Main Filter Pump
Airblower
Lights
Thank you
