How do you release pressure? When I first installed it the gauge was in the green at .5psi I came home and turned it on so that pump can pump at night instead of the day. Well the pressure was in the green still but it was more then .5 should i be worried? if i need to release pressure how do i do that? Also this is my first time owning a sand pump filter. Do I do the same testing and chemicals the same as I was doing it before with a cartridge filter?
Thanks
Thanks
