In the mean time, while I wait for the ground prep I’m trying to decide on a few things:
What I want to put under the pool. I’m leaning toward XPS foam and it looks like I can get 1/2 inch foam at both Home Depot and Lowes in this area, but I’ve also seen people using anti fatigue mats, which would be about the same cost from Harbor Freight.
Whether I want to go with a through the wall skimmer or just the intex in the pool skimmer. I used the intex one on my 15’ pool and it worked reasonably well, but it also got in the way occasionally. I feel like with the bigger pool it might not be as much of a problem, but the through the wall skimmers are a much cleaner install. I’m not too worried about cutting the liner, but I am concerned about the water level. I want the water to be as deep as it can be and I’m concerned that the through the wall skimmer may cause me to lose a few inches of depth. If you have any suggestions here I’d be happy to hear them.
Which steps to get. I want a large set of steps that will attach to the deck, rather than a ladder for this pool, but I’m not sure how that will work with the liner that curves in at the bottom of the pool. Obviously I want the steps reasonably close to the edge of the pool, but I don’t want it to press against the liner at the bottom. Right now I’m looking at the Confer Curve steps or possibly the Lumi-O Royal Entrance 2. The confer steps seem to be well rated, but again, I’m concerned that they may not be able to fit back against the edge of the pool. The Lumi-O steps are much more expensive than the Confer ones, but definitely wouldn’t have a problem with the liner. However I’m also concerned about an automatic vacuum getting stuck under the Lumi-O steps. Again, any suggestions about steps would be welcome
