- Jul 21, 2013
- 65,526
- Plaster
- Pentair Intellichlor IC-60
Would it make a difference if the 1.5hp spa pump is closer to the pool?
No
So which is he proposing AquaLogic, ProLogic or Aquaplus? AquaLogic has been discontinued for some time now.
1) They use different breaker boxes so it would require removing the entire unit and replacing it with another plus all the wiring. See if he will give a credit for no control unit.
2) Yes, the cell is the same between the two.
3) The descriptions and manuals are online: Pool Automation | In Ground Pool Automation - Hayward Pool Products
The SuperPump and TriStar have different port heights so it is not a simple swap. Plumbing would need to be rerouted. You might ask for a TriStar single speed and then it would be a simple swap. He shouldn't ask for much more.
The prices for these upgrades seem very high to me like he is taking advantage of you. What is the build status? Given this and the plumbing design, I might consider a different PB.
At least get him to draw up a schematic of the plumbing so we can review it. It is a common screw up by many PBs. Not surprising, we get many complaints on the forum of poor performing spas and water features but after the pool is built, it is almost impossible to fix without spending a lot of money.
BTW, the ProLogic is not a bad controller. Was there some feature of the OmniLogic that you wanted?
Ok but you can add the AquaConnect to the ProLogic for app control. ProLogic will also control the lights and valves.
Regarding pumps, did you see recommendation from mas to request the single speed TriStar instead? If you had unions installed it'll make the plumbing switch to Tristar VS easy. I wonder what the PB will offer once the new federal pump rules kick in July 2021?
Regarding tethering lighting and sound to the shed, how far will that be from the pool edge? The National Electrical Code states you'll need that 10 ft away, even for low voltage lighting. I think there were later revisions so you need to double check on that.
Equipment | Hayward |
Controller | Pro-Logic Plus w/salt generator |
Lights | Color Logic |
Heater | H-Series Natural Gas 300,000 BTU |
Filter | Hayward Pro-Grid DE 3620 |
Pump | Tristar VS 950 2.7HP |
Spa Booster Pump | 1.5 HP |
I cant say either way I'm not there to see the dirt. I will say I've never backfilled with native material and I never will....unless their lawyer amd mine write up a co signed hold harmless with no deck warranty....then I'll backfill with anything they want
It would take years not months for that mother nature to settle that dirt and it Will never achieve the 95% compaction recommended for structural stability, so the one year warranty really does not mean much. You would be taking a large gamble not using the stone. What usually will happen is things will be fine for several years then something happens to introduce water under your deck where it has not been before. This could be a leak in your liner, someone accidentally leaving a hose running, pool overflowing or even just a area of lawn with minimal pitch that has grown to start forcing water under your slab. That water will settle the uncompacted material and leave large voids.the pool will sit from November to March/April before the decking is installed. I also found out that the warranty for the decking is 1 full year against any cracking or bowing. So im wondering if I could just save that 2k and put it toward other areas of the build.
Would the 5 months be good for settlement?
3/4" clean gravel needs almost nothing after it's in. I run a plate a little ways away from the walls halfway up and then when done for peace of mind. They just need to be sure theres no organics in the overdig like branches and leaves
