- May 3, 2014
- 62,792
- Fiberglass
- Pentair Intellichlor IC-40
With a SWCG, the nice feature to have is the VS pump. You can dial down your rpm to just be able to close your flow switch. And with the ET coordinated with the SWCG you can use 1% increments vs 20% without the ET.
A two speed pump will work. Your low speed will be somewhat higher than you need to close your flow switch, and the high speed might be a bit too high for the bubblers/jets.
Take care.
Take care.
