Hi all,
Two week lurker, first time poster.
I've done some things wrong already and some things right, hopefully the TFP gods will be merciful and generous with their advice.
I have just bought a house and initially wanted to outsource the pool for the first season since I have a long list of things to get accomplished.
(I think I put my pool details in sig, but ~25,000gal plaster/concrete)
Here is are my questions and comments:
Thanks, be kind if possible, but all useful criticism is welcome.
- I hired a pool company to open the pool,
- they suggested I replace a 30yo brass always-on pump and a sand filter with a cartridge and and intelliflo vs+svrs.
- this was agreeable to me for safety feature (single drain on my very old pool) and power consumption, and locally I have rebates
- cartridge filter seemed like it would ultimately waste a lot less water vs backwashing the sand, and filter more finely
- that's now installed and running, so post-hoc criticism of this choice I will submit to as penance, but I can't undo it and it would only make me feel bad.
- They got everything going and sold me a big package of BioGuard I didn't need, which I read this forum in between that purchase and now, before even using a single tablet or cal-hypo pack, and am now attempting to return unused (wish me luck)
- They did open the pool using a shock product I didn't write down the name of, and old tablets from previous owner in the skimmers. Those are now mostly dissolved.
- The tested the water at that time using a 1200v fas-dpd multitest and had mostly acceptable parameters, from hazy memory
- 180 hardness
- 7.6 Ph
- 50-60alkalinity (? not 100%)
- The pool improved in color for three days, but didn't improve in clarity.
- The previous owner appeared to have left the pool open and unmaintained into late autumn before last-season closing,
- I leaf-skimmed literal pounds of leaves off the bottom during this time
- I brushed as well
- I vacuumed and got more small leaf matter
- Then I read this forum really a lot and decided to do the SLAM using liquid chlorine.
- I started that process and noted the Ph was very low,
- my TF100/digital Ph isnt here yet
- the strips I am using show <6.8 reliably, the Phenol Red test shows < 7.1 reliably.
- I understand Ph isn't reliably during slamming but from everything I've read, It should skew _higher_ than normal if adding liquid chlorine with Ph of 13.
- test strips also show 40 alkalinity, 0 CYA. I do have a black dot CYA test from another kit I have lying around and that also confirms low CYA.
- test strip other results:
- 250 hardness
- > 10TC
- > 10FC
- <40 CYA
- Yesterday I added 8lbs borax and 3lbs baking soda to work on Ph, test strips show no change.
- The calculator calls for 27 lbs of borax if the Ph is actually 6.5
- I don't know what the Ph actually is so I hedged my bets here, but have seen no change on strips or Phenol Red test
- I also added 1lb of dry CYA in a sock and that has been dissolving very slowly, like hardly at all unless I squeeze the sock.
- The calculator calls for 4lbs
- I hedged my bets in case there is a delayed load from the tablets, and also I don't have a sock big enough for 4 lbs of CYa.
- OCLT this morning showed 10FC --> 3FC while I slept (i didn't intend to let it drop, I just left that house at 8pm and didn't get back til 7AM, so i guess that counts as OCLT right?)
- General water quality is blue/teal but cloudy. Drifts of pollen on the floor of the pool, don't think it's mustard algae, not on the walls.
- I can see light/dark on the floor of the shallow end that gets distrubed when I use brush or leaf rake (pollen?)
- I can't see the tool I'm using when it's on the floor of the shallow end.
- I can't see anything at all in the deep end, including the bottom of the ladder.
- Suspect previous owner used lots of copper, think I see a blue stain near return jet.
- previous owner mentioned he had flocced it , attempting to open before the house changed hands. I don't think that was ever vaccuumed to waste.
- I don't think I have the capability to vacuum to waste with my current setup? I did vacuum normally as stated.
- this sucks
- I have worked really hard to try to clear leaf debris off the deep end, but I can't see it and don't really know how well I've done.
- I can no longer bring up huge scoops of leaves, the leaf rake gets 1-2 occasionally, most deep-end rakes bring up nothing now.
- The vaccuum only partially filled the pump basket with bits last time I did it.
- Should I keep trying to bump PH up while I SLAM?
- I would like to continue to SLAM while I wait for the test kit if at all possible to not have wasted the chlorine so far. Should I abandon and write it off as learning experience until test kit in hand? (Not sure how many days out it is, post office has sucked lately in my area though and it's coming USPS)
- I apologize in advance for posting this without proper TF100/Taylor reagent results in hand.
- I understand that accurate test results are the cornerstone of pool maintenance.
- I am wondering if such a low Ph is an urgent corrosion issue or affecting the slam and I should be dumping borax or soda ash even before I have the kit in hand.
