Just Bought new tub and having problems
Tap water is as follows
PH 7.8
TA 210
CH 240
Brought TA down to 80 using dry acid. Doing it slowly and aerating as I went to bring PH back up. Added some Boric Acid to get 50 ppm. Also added some scale preventer to help with high Calcium. As I near the end of the dry acid procedure the water seems to cloud up and leaves white dry water marks on surfaces. Did this twice now after draining the 1st time but same outcome. Any ideas what i'm doing wrong.
Testing done with a Taylor k-2006c
thanks
PH 7.8
TA 210
CH 240
thanks
