New here but this is my 4th season with our pool.
When it was built, we had the frog system installed. Seems like it worked well but was expensive.
Last year I just cut open the frog paks and added 1" trichlor tabs. That also worked but I noticed the system couldn't keep.up with the amount of chlorine needed since the frog systems uses much less chlorine than traditional chlorine systems. With the pump running 24/7 1" tabs could only produce about .7ppm
I've been reading up here and this year I have tried the liquid chlorine method.
I seem to go through alot more chlorine and more $$$ than I did buying the over priced frog paks.
My current readings are
Ph: 7.5
FC: .2 (didn't add chlorine today yet)
Alk: 110
Hardness: 240
CYA: 65
35,000 gallon vinyl pool
To get my FC up to 4-5ppm I need to use over 1 gallon of 10% chlorine.
To do this everyday is about $7 worth of chlorine
That's about $50 a week for chlorine.
The frog paks are roughly $25 each and last a week. I know these will also raise CYA which will eventually need to be partially drained and filled
Does everyone seem to use about a gallon of chlorine a day?
I live in western NY so sun is hit and miss still.
Here's a Pic of my pool
Ph: 7.5
Alk: 110
Hardness: 240
CYA: 65
