- Nov 15, 2023
- 48
- Plaster
- CircuPool RJ-60 Plus
Hello all from Surprise AZ! So I came from Washington state, so I have no idea about anything pool related. The pool looked great when I bought the house a month ago, but I figured I’d drain it and clean it since the jets are loose and there was some staining on the floor and it hasn’t been drained in 8 years.
So it appears to be a colored plaster with quartz. Has a couple cracks I need to fix as well. Info on the web is conflicting at best.
Some info first:
15,000 gallon oblong pool. Everything works. Water level is halfway up the skimmer. Skimmer baskets cleaned daily. Pump is on 6 hours a day at 2400 rpm (1 hp pump). Jets are pointed just under surface and in a circular pattern back toward the skimmer. MX6 robot with the black lever thing on the pump at roughly 50/50 vacuum/skimmer.
1) The skimmer doesn’t seem to skim the surface despite my best efforts. It’s pulling in lots of water but the surface just remains dirty, especially if there’s a cover on it
2) Is acid washing my pool fairly idiot proof? Anything to look out for, or additional products to use?
3) While it’s now empty, is there anything else I should do to the pool before filling it again?
4) Is there a way to remove the massive calcium line on the tiles? I’ve tried every chemical I have with a steel brush on a drill, and not even a spec of it comes off.
5) Do you have to replaster the pool at some point, or can I keep repairing cracks forever? Pool built in 2003. Cracks are small but long, but they have cracked a couple tiles.
6) Anyway to get my robot to stop getting stuck on stairs?
7) Are the eyeball jets the best kind to get since I’ll be replacing them?
8) Do pool cover reels work well with oblong pools?
Well, I think that’s all the questions for quite a while.
Here’s a pic of the pool if it loads.
Some info first:
