Hi All,
We currently have an Anthony VA-52-2 DE filter for our ~19K gal in-ground, enclosed pool. The filter grid needs to be replaced and I'm seeing prices starting at about $500. I can do the work to replace it myself. The filter is the original equipment from when the previous owners had the pool built in about 1981. I've been told be a few "pool folks" that I should not replace the filter because it will never stop working. Same with the pump, which is also the orig. Obviously, from the model number, it is a 52 sq ft filter. We use chlorine, usually 3" trichlor tabs (a couple of tabs lasts a couple weeks for us) or bleach, with Dichlor to start the season.
I'm considering having the filter replaced with a new cartridge filter just to get a away from the annoyances of this old filter and getting the seal tight when putting it all back together each spring. I'm guessing that I would also need to replace the push-pull valve with a multiport valve as well. I rarely need to backwash since the pool is enclosed. In looking at filters on Doheny's, I see most cartridge filters are A LOT bigger than 52 sq ft. I have a few questions...
Thanks for any help you can give!
Tim
- I found one 50 sq ft filter. Would that suffice?
- Is it okay to go over the sq ft'age? 120, 150 sq ft?
- Are the ones that are 300-400-500 sq ft meant for commercial size pools?
- Is there a more appropriate filter type to get?
- Do I need to replace the valve also? The current one is metal. Copper, I'm assuming.
Tim
