New construction in Central Florida
Sarducci
21
Northeast Florida
looking good. That is a whole lot of plumbing. good luck with all those valves. Hopefully the Pentair automation will handle most of that that. What is the antenna looking device next to your easy touch box? I'm in the process of building as well in Northeast FL.
jfarthing84
Active member
May 7, 2019
41
Daytona Beach, Florida
That is the ScreenLogic module, which allows you to control the automation from your smartphone/tablet/PC.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,898
Now would be a good time to post a set of current test results. It will jump start you in the right direction.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,898
FC: 0.2
PH: 7.8
TA: 70
CYA: 0
CH: 60
Almost perfect. Over a period of the next 90 days or so you will want to see your CH increase to around 250. It will do so on it's own to an extent but you may need to add some to get it there. Of course you will need to add Chlorine and CYA per the suggested levels. Your pH and TA are just right.....don't change a thing.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,898
With a current pH of 7.2 and TA of 40, that certainly looks like someone put some acid in there and there was no need.
It would be a good idea to request that your PB tell you what he is adding to your pool.
