Dirk that format works great! Very easy to read.
tytyty=thank you ,thank you, thank you!
Kim
Kim
When they applied the pebble was there sand still in the pool? I remember you saying they got a lot out but if any were left in, it would have been embedded in the pebble mix. I really hope this isn’t the case. What a stuff around.
Morning all, and thanks for your input on the acid wash. My gut was telling me once again to … ”let it go”. I read some threads on TFP about acid washing, and has leaning (heavily) leaning against it. This is one more thing I will bring up when my final payment is due to use as collateral for reductions.
ONE MORE thing on my list is the spillways. There are three of them. When the first fired them up I pointed out that one of them was barely spilling any water. A bit later they said they adjusted it.
I know understand that they just increased the speed of the pump (temporarily), but when they programed it to come on everyday for 12 hours, they reduced it back down.
Is this fixable by:
Breaking that tile out and replacing it slightly lower?
Just run the pump at a higher speed (for shorter periods of time)
Is this another thing I should let go of?
Hi Riley00dog, My recollection that there was no winds/sand prior to the plaster/pebble going down. Here is a photo of what it looked like about an hour after they left after blowing the plaster in. I think as the day progressed and the plaster dried the slight variations evened out.
Hi PoolGate,
These are spillways, so there is no controls, just the speed of the pump inside the spa (that I know of). We do have three deck jets that are all controlled by separate valves. We like the fact that we can dial them in to spray the same or different distances.
I'll let Kim or others handle the chemistry. Enough cooks in that kitchen. Except to say two things:
- get the FC up, right away. Don't wait on that one.
- if your CYA is 34, and you think you need to add 55oz in a 9700G pool, that indicates to me that you've still got Pool Math configured as if you're running an SWG pool. You're not. Your pool is currently a non-SWG pool.
And if you have that setting wrong, then that will throw off most of your other Pool Math numbers as well. Be sure you have that right before you go dumping in chemicals. I explained that in depth in a previous post, about how to set that setting and how it affects your recommended ranges, etc. Did you get through that post?
