Hi All,
I have learned a lot from the forum over the last few months. I am finalizing a bid for my pool and want to get input from the members on the selections/decisions I am making. The pool builder only uses Heyward equipment.
- Salt water pool, 32 ft long and 18 ft to 22 ft wide. ( I have attached the pic)
- 8 x 6 spa, 12 inch raised, rolled edge. Should I increase the height to 18” (at added cost) to make it easy for people to use it as a seat? Or make it flush with the pool and save around $2k. Does the rolled edge worth at $600
- Hayward TriStar VS 950 Omni Pump with Smart Pool Control. This is 2.75 HP . PB wanted to install 1.85 HP. I requested to upgrade the pump at $600 cost. The pump contain smart controls for other components. No separate automation system
- Upgraded cartridge filter from Heyward 4025 to 5025. Cost $300
- Upgraded Heyward heater from 250k BTU to 400k BTU. Cost $600
- Extra space for chiller on the pad
- Auto refill. Cost $500
- Two skimmers independently plumbed
- Salt system for up to 40,000 gallon
- 2.5” plumbing
- Pool depth : 4’ to 6’
- Spotter tiles on the steps. $400
- 60% quartz plaster. Upgrade cost $2500 over white plaster. Should I done this upgrade or spend more to get PebbleTec or keep the white plaster?
- PB is charging $500 to seal the travertine coping. I will be getting decking done separately and planning on installing travertine. I might get the deck sealed. Should I request PB to not to seal the coping and I will get it done with the deck? Anything important to do when getting decking done separately from pool builder
- I am getting 4’ sheer decent. Will it be fine for the pool size or should I get one scupper each on both sides of the decent?
- PB is saying that one 2.7 HP VS pool is good for everything. I have seen people here recommending separate pumps for water features and even spa. Should I get extra pump? Down side of one pump?
- Pool builder recommended one colorlogic led light in the pool and one in the spa? He is saying that they use “big” light in the pool and one is sufficient. Do I need another light in the pool. It will add about $1000 or so
- I am planning on getting a covered structure on the right side of the pool. Should I move the pool and spa a little to the left?
- Anything else I should ask/add/remove?
- Thanks a lot in advance.
