Sooo... Plumbers came yesterday and inspection is scheduled for Monday... they did a few things that I'm not too happy about, but I'm planning on sending this information to my PB to see if they'll take any of the responsibility.
1. EXISTING RETAINING WALL
I had a retaining wall built 2 years ago to give us room for a deck/ screened in porch. This existing retaining wall has been compromised, most likely from the driving the digger/bobcat between the pool and wall. The wall has been pushed out and the caps are no longer level. Too bad I don't have a video of them driving here but I have photos of a before and after.
2. IRRIGATION
Last night I noticed the garage had been flooded, so I went in the crawlspace to see if it was from our irrigation. (The irrigation comes from a well, and goes to a container in the crawlspace... I don't really know how that ever worked, but it was done before we moved here). The container was tipped over and one of the pipes were bent. I can't prove they caused this, so I briefly talked to one of the guys last night just to confirm they used our city water instead of well water (our well water is only for irrigation since it stains everything orange). He had no clue which one he tapped into, but I'm pretty sure they used the correct one. It's the same source I used to mist the pool, so that was good. However, he mentioned when he dug, a lot of water kept coming up on the outside of the house (the other side of where the irrigation container is in the crawlspace). This morning as I walked around, I noticed they cut the irrigation tubing in several places by the house. Not that we use it anymore but it's still irritating he never disclosed that.
3. ELECTRICAL WIRES
Last night I noticed the lighting previously installed on the retaining wall wasn’t working and a GFI outlet was tripped in the garage, which cannot be reset. This morning I noticed - what I think is - an electrical wire cut in the same area where the irrigation lines were cut.
4. EQUIPMENT SLABS
The equipment slabs are not level to one another and seem to be undersized for the equipment. I was under the impression there would be one decent sized slab to hold all the equipment.
I’m not sure if these are issues that can be corrected, but do I have any options at this point? Do PBs correct these or do they challenge you and say it's your problem?
Thanks!
