- Dec 5, 2016
- 111
- Plaster
- Pentair Intellichlor IC-60
Greetings all!
I am in the middle of construction of my new in-ground pool, and thought it was time to get some answers before the equipment goes in and startup begins. Why not start with some pictures.
The yard before:
Sketchup I'd been working on for years:
Some lines on dirt after everything was removed:
Where it sits today:
Tilework detail:
My goal was to have a pool that fit the 50s aesthetic of the house, hence the tiling, and the eventual decking which is going to be a monolithic acid-wash concrete. My yard has a natural slope so I embraced that, and the pool will sit 18 inches tall at the patio, providing bonus seating, and then the rest of the yard will be built up with the pool excavation material yielding a small raised grass area and some planters behind there.
I hate hate hate pool fences, and I felt a little guilty about water use so I designed the spa to be fully inset so that the whole thing can be covered for safety and water/energy savings.
Specs:
35 x 18, 106 feet linear perimeter, ~22K gallons
Min depth 3.5', Max depth 8'
7 x 7 therapy spa with 6 jets, bench heights of 1' , 1.5' , 2'
1 skimmer
3 surface returns
3 auxilary returns
Pentair CCP520 Cartridge Filter
Intelliflo VS (no further details)
Pentair IC40 SWG
Pentair 400K BTU natural gas heater (no further details)
Caretaker 8-port in-floor cleaning system
EasyTouch automation (no further details)
Pentair 5G white LED x2 for main pool, "300w" in shallow end, "400w" in deep end
Pentair 5G White LED + 2 RGB globrites for spa
Coverpools Automatic cover
PebbleFina interior - "Sapphire Galaxy"
And now some questions!
1. Are there specific models of the Intelliflo VS, heater, and easytouch panel I should make sure I'm getting?
2. Because the pool will have a cover, should my chemical balance be more like an indoor pool? I'm thinking specifically of chlorine loss due to UV that should be significantly reduced.
3. Related to #2, will startup be different than the regular plaster startup I've read about?
4. Also related to #2, should I expect that I need less turnover since the cover should keep a lot of debris out, and lack of light should prevent undesirable growth?
And one major gripe
The state of pool lighting is abysmal. I could not find, for the life of me, a warm white LED that was dimmable with the automation system. And you can get color adjustable RGB-- bit they don't have pure warm white mods. And they're bloody expensive. I finally got fed up and got the intellibrites that use a regular niche in the hopes of being able to replace them someday.
The yard before:
Tilework detail:
Specs:
1 skimmer
3 surface returns
3 auxilary returns
Pentair IC40 SWG
And one major gripe
