Hello - New to the boards and I have been absorbing as much info as possible on maintaining the pool but as I am now getting construction plans I am starting to fall into the bottomless pit of the overwhelming amount of info out there on plumbing (well everything pool related). Nonetheless, there is tons of info out there and so many experts, I am not one (first-time pool owner to be), and I was hoping to get some perspective and guidance. I am building a small geometric gunite pool (12,250 gallons) in N. Texas (basic info: no trees, full sun all day, planning to do liquid chlorine).
I reached out to my builder to inquire about doing larger pipe sizing and possibly adding a second skimmer. The response doesn't seem to be saying I can't but I just thought I would get more info as it sounds like I may not necessarily need to.
My questions to the builder/salesperson and their response: (Does this sound right or should I push to make the changes to match return to suction and add the 2nd skimmer)
Question: I was curious about plumbing lines, I know you mentioned 1.5-inch PVC lines were the standard, I see many of the Jandy pumps recommend at least 2 inches and the flow rate is much better on 2 inches, is it even possible to request 2 inches?
Question: Are we able to add a 2nd skimmer? I see we have 1 listed but I would prefer to have at least 2.
Thanks for any and all guidance.
- Answer: That is referring to the suction and we use 2 1/2 inch plumbing so we are good there. For the returns, the industry standard is 1 inch and that is where we use 1 1/2 inch.
- Answer: We definitely could do 2 skimmers but it really wouldn't help. If you had 2 skimmers, then, it's sort of a waste to have a variable speed pump because it would always have to be running at a higher level to have enough pull to make both suction useful. Currently, you have 1 skimmer and 4 returns, you can upgrade to 2 skimmers and 6 returns but on the lower settings of the variable speed pump (which helps to save you money), you will have very little water coming out of the last 2 returns unless you crank the variable speed up which defeats the purpose of having a variable speed. Does that make sense? 1 skimmer is truly sufficient for your size pool but I will do whatever you would like. To upgrade to 2 skimmers, it would be an additional $850.
