If you mix the pool water to the line then the CYA regent to the other line then you did it right. I am guessing they did not add any CYA. Did they put tablets/pucks in your skimmer?
The next time you go to town run into Lowes or Home Dept and go to the pool section. They should have some CYA. Walmart will have it as well but they may be busier than the other two.
Now when you go to add it do NOT follow the directions on the bottle. What we like to do is put it in socks and hang them in front of a return. Don't let it touch the sides. You can hang it off a broom handle wiht something sitting on the other end of it.
Kim
Kim
