~Advice~
If your easy touch is mounted to a east/west/or south facing wall, it’s going to take a beating from the sun. So consider building a vented enclosure for it.
Also, not sure the direction you’re going in with the equipment pad, but that too is going to take a hammering from the sun. Those blue handled valves (not a fan of those at all) will be the first to give you problems.
If that pad will be walled in with block, consider a simple pvc framed top wrapped in solar screen to protect your equipment and plumbing from UV damage. If nothing is planned, then a simple plastic or wood shed to go over/around it, will keep it all in good shape.
Use the search at the top of the page, and you’ll find some great threads discussing that topic.
