Sent you a PM since I'm not sure if we're allowed to call out specific PBs here (I might be off base but feel like I see a lot of PMing of PBs as opposed to thread discussions).Looks great! Curious to know who your builder is? They are using a similar build technique (Plumbing before steel, Pipes run under the pool and covered with flowable fill), to my PB which seems to be different from a majority of the builds I see on here, where plumbing is run around the pool, and plumbing is laid after steel has gone in.. I not really sure the benefits of either, just a different way of doing it.
Thanks! Not quite yet. Don't think it's allowed for at least 2 weeks. And still need the PB's stone mason to route the channel across the decking I'm going to run the line over. I will definitely post when it happensLooks great!
Have you gotten your Dolphin M600 yet?
We are using the same builder. They have not gotten mine yet and our plaster is cured. You may have to keep bugging them for it.Thanks! Not quite yet. Don't think it's allowed for at least 2 weeks. And still need the PB's stone mason to route the channel across the decking I'm going to run the line over. I will definitely post when it happens![]()
Good to know- will start asking themWe are using the same builder. They have not gotten mine yet and our plaster is cured. You may have to keep bugging them for it.
