Good morning everyone! I have been on an off trolling in here for years. I am finally taking the dive and installing an unground pool (partly DIY which I will explain below) and I have a few questions. Here is my specs:
For the electrical, I will have to run a line down to my pool area and put in a sub panel. Well, I'm not quite sure how much power I will need here are my following items I think I will need, power wise:
Chris
- 18x36 rectangle Inground Vinyl Liner pool (8ft step on left Side of shallow end if you are standing on shallow side)
- Compsite walls
- SuperFLO vs 1 1/2 HP 110v/220v
- Sand Dollar SD80 top mount filter
- iCHLOR 30 SWG with power center bundle
- 2 TREO LED lights with transformer
- pool pump
- chlorination system (SWG)
- Led lighting
- some power outlets(maybe 4) for the gazebo area and possibly a hot tub down the road.
- GFCI outlet for a cleaner (possibly down the road)?
- Will I need an intermec timer with the SuperFLO VS pump?
- Any wiring diagrams to include the bonding would be extremely helpful
- Not sure of the layout yet I think there are 2 returns, main drains and 1 skimmer.
- I listed that I have a SuperFLO VS pump, iCHLOR 30 SWG and sand filter....there will be no heater installed!
- Any diagrams or help to make sure I lay it out correctly would be greatly appreciated.
Chris
