You are really using up your whole back yard. Make sure you have plenty of walking space between the pool and the screen enclosure and between the screen enclosure and the fence. I have the following suggestions:
1. Speaking from experience. Put in a double door on one of the sides. I only had one door and ended up putting in a double door and another single door on the opposite side. I should have listened to my wife
2. Plan on plumbing electrical and water for a future summer kitchen.
3. Plan on adding solar and heat pump in your equipment pad.
4. Make sure that you have a very large equipment pad, our equipment pad is 19 ft long x 9 ft wide.
5. Put in water spigots in all 4 corners of the screen cage both inside and outside the screen cage.
6. Put in electrical outlets in all 4 corners of the screen cage both inside and outside the screen cage.
7. Go with a large outdoor space as possible. We have 1800sq ft of pavers and we wish we did a larger space. You will be quite surprised how much room tables chairs and lounges take up.
8. Run conduits for speaker wires if you plan on wired speakers.
9. Put in footers for future screen cage. Some people do not like the pool cage however we believe in it as we swim a lot at nighttime.
10. Plan on positioning your pool so that you can watch TV comfortably when you are in it. I know that this may sound strange but we love watching TV, football games, NASCAR races and movies when we are relaxing in the pool.
11. Place pool light facing away from the house, we had ours facing towards the house and we notice some glare from it.
Look at the 3 links in my signature bar for ideas. Post lots of pics
