Thanks! It is hard to tell from the pictures, but the stone surrounding the slide matches the stone on the house.Love the finish stone around the slide! Good pick!
Thanks Winger!Slide looks great! You have a wonderful build!
That tile area is a NO GO! That is NOT acceptable at all! They need to remove and redo the whole line. It will not be easy or fun to do it right BUT if they take their time and use some pride in their work it can be done MUCH better! Gurrrrrrrr
Slide looks great! Are you using buff lueders for the coping? We're planning on the same - looks great in your pics. Are you happy with how it turned out?
You have extra pad space to the left but because the pipes came up where they did, they just fitted the pumps in line and move filter and heater to fit. One idea, although probably not ideal - can you shift your HVAC units over to the right more? That will cost more but could solve the issue. Ideally you could move the heater to the far left but it adds longer flow pipes.They put the heater like right on top of my HVAC while the manual says it should be at least 36" from an HVAC. Is there any reason that they couldn't reposition the heater over closer to the filter instead of being so close to the HVAC? If not, any other recommendations for placement?
Based on what is shown in the picture, it appears to work the way you wish to handle the flow.The "spa makeup" return line (to be able to have the spa spillover going while the pool is in normal clean mode if desired) isn't exactly what I had drawn up on the schematic that I gave them (and they seemed to just completely ignore). However, I think that the way that they have it should still work as desired (i.e., if I don't want the spillover going turn that valve off, or if I do want it going open that valve up some). Am I right to think that part is okay?
If you move the heater to the far left, can you just run long horizontal pipes for inlet and outlet behind the filters (against the wall). It would create a longer run but when it comes back to where the SWCG is you can then move the Inline Chlorinator to be after the SWCG as you desired. Ensure there is a check valve before the Inline Chlorinator.Assuming I need to have them move the heater to the left on the equipment pad to give the HVAC some room, is it okay to have the pipe go up vertically out of the heater, then pull a u-turn and head back down then put the SWCG
Wow - what a set up. You have lots of room between equipment which is great.
Note - they need to rotate the top of the heater 180 degrees. That control panel needs to face the front of the pad. Its doable because they did it on mine.
Not sure how you can put in the heater bypass because it is hard to see all the flow pipes but appears doable especially if you move heater to the far left.
Other
Not sure what automation system you have - but if you plan automate a lot of those valves, such as the water sheens, hopefully an IntelliCenter because you will need lots of relays to control that.
Sparks,
In theory, the IntelliFlo breakers are not supposed to power anything but one IntelliFlo and a SWCG... (Check out the IntelliFlo manual)
In my mind, four 240 volt GFCI breakers for the pumps would take up 8 slots...
The lights most likely would only need one 120 volt slot
Blower would take one 120 volt slot..
There is no reason to have the heater breaker inside the automation...
There are still things not listed... I like to have a breaker for just the SWCG, control transformer, GFCI outlet, equipment pad light, anything else you want to power later???
I only have one IntelliFlo and no heater and I have no spare breaker slots..
Any update on this pool?
