- Jun 7, 2017
- 9,178
- Plaster
- Jandy Aquapure 1400
So it is possible that nobody is following this thread anymore but if anyone is out there, please help me if you can! I opened our pool the weekend before last...surprisingly it went OKay! I was a little nervous and so I think it took me longer than it should have, but I got everything running. Discalaimer: My pool needs salt. I put in one bag and then tested with my new test strips; I'm a bunch of bags low. I had forgotten about the 1/3 drain the PB did in order to finally fix my light last October.
Anyway, when I got my equipment restarted I had a system alert from screenlogic that said 'Chlorinator: Cold Water Cutoff'. When I first got this message after I opened, I looked it up and found that that will happen when the water is below 60 degrees. The water was around 58 degrees so I wasn't really worried. Now here we are ten days later and screenlogic is telling me that my water is 70 degrees but I still have the same message about the chlorinator.
I have no idea why this is nor how to fix it. Should I just try resetting everything? I know it needs more salt, but I'd think I would get a different message than what I'm getting. If I have to reset/turn off the SWG can someone advise how I do that? Thank you if you can help!!!
The Jandy TruClear also says "low temperature cutoff" or something like that when it is either cold or low on salt. You need a better test kit for the salt. My guess is your salt is low. Guess strips are not a good way to test salt. Feel free to stop by I'll let you borrow my K-1766 to test with. Or bring a water sample down and we'll test it here.
