Never had this happen before - pH seems to be dropping?
JimMarshall
1,193
Oil City PA
Without any intervention from me? Has gone from being in the high 7s to the low 7s (most recently 7.3) without me adding any acid other than CYA (which affects it but it is negligible). My TA is normally high with the fill water here, and as such my pH always drifts UP and I must add MA to drop several times a year.
Also, my pool water tastes icky. I know that its not supposed to be drank, but its inevitable to get some in your mouth.
Latest numbers
FC 6
CC .5
pH7.3
TA 80
CH 300
CYA 50
We've been getting A LOT of rain here... Is it possible that the rain is just very low pH compared to "normal"?
The only way pH lowers in pool water is from a chemical addition or the addition of acidic water.
Did you recently add CYA? CYA is mildly acidic and will lower pH some
That is really puzzling. As marty posts above, pH doesn't go lower unless you add some low-pH chems or acidic water and rainfall can not account for that swing.
If you ever figure it out, patent it quickly because a lot of folks would use it!!
Reactions: afbatts
Is the TA also going down?
How many inches of rain have you received?
Are you getting the water sample from the top of the water where the concentration of rainwater might be higher than the rest of the pool?
So your next experiment will be to capture some rain water and test its pH.
Hopefully I'll be able to do that today.
Actually it's been going up, but I had older testing reagents that I just replaced
Since the pool opened? About 30
I am, hadn't considered that.
This morning I was at 19.5 and 1.5 CC - water crystal clear. I might have screwed up and let the chlorine drop for a couple days (life gets in the way sometimes).... but at least whatever it was that I was about to have an outbreak of..... I seem to have been able to "head it off at the pass"
